what is wrong with engine
johnr
12-09-2003 20:14:21
I bought a Farmall 130 that ran on two cyls,was thinking stuck valves but a compression test showed real good and even pressure.I next found the firing order was messed up but with the correct order it would not run at all.Are the timing gears out of sequence or something else? thanks for any help
George Willer
12-09-2003 20:44:58
 Re: what is wrong with engine in reply to johnr, 12-09-2003 20:14:21
It's something else! It was running on the two that were crossed because the mag/distributor is 180 degrees out of time. It's an easy fix... I hope you lucked out on the price.
George Willer
