Order Farmall Cub Parts Online
Farmall cub won't start
Roger
11-23-2003 15:40:49
I'm getting spark from the coil to the cap but not coming from the cap to the plugs. I have put on a new distributor cap, rotor, points and wires. Does anyone know what could be wrong?
Thanks
Bigdog
11-23-2003 16:15:55
 Re: Farmall cub won't start in reply to Roger, 11-23-2003 15:40:49
There are different caps for magnetos and distributors. Make sure you have the right one. Also make sure the rotor button is installed correctly. Check the static timing.
old
11-23-2003 16:04:16
The cap or rotor may still be bad, or the wrong parts. Or something is grounding out the spark from the rotor to the cap.
Hope this helps some
