Throttle settings for 1949 MD
Reed Nichols
11-21-2003 20:40:36
How do I adjust the throttle on the diesel side of the motor for the MD? Not a born diesel man and I'm having trouble getting the settings correct. Any help is appreciated.
Haas
11-22-2003 03:42:22
 Re: Throttle settings for 1949 MD in reply to Reed Nichols, 11-21-2003 20:40:36
Are you talking about the tension on the throttle?? There is a friction plate adjustment on the right hand side of the engine block. The MD throttles are usually pretty tight and take quite a bit of force to move. That friction plate housing has all the latches, etc it in for the gas to diesel switch over. I strongly suggest you get a manual. I'd get all three, the parts catalog, the operators manual and the service manual.
