Farmall Red vs. Farmall Grey....
Luke
11-18-2003 04:23:19
i know that farmall changed colors on Nov.1,1936.
does anyone know the breakdown of the serial numbers to determine if your '36 is a pre-Nov.
model? i have a '36 F12 (FS65032)which most of which appeared red....i am looking at an F30 that is also a '36...very popular year...(forget the exact ##)
i just want to be sure it is a post Nov.1st model.
i want to complete the '36 line up.....in RED.
thank for your help.
Luke
Dan in Ore
11-19-2003 03:03:32
 Re: Farmall Red vs. Farmall Grey.... in reply to Luke, 11-18-2003 04:23:19
I have a 36 F-12 that showed no signs of gray when I stripped it for painting so it got painted red. Got another 36 that definitely has gray under the red. It will get a couple of coats of gray paint.
Dan
Luke
11-18-2003 06:15:23
thanks for all of the insight.....
if i understand this correctly..... all '36 should still be gray..... '37's should then be red??
is this right.?
i may have painted my F12 incorrectly....too pretty to change her now.
thanks again.
Luke
F-Dean
11-18-2003 04:50:19
According to an article in Red Power a couple of years ago, the first red F-12 was #FS-81837 and the first red F-30 was # FB-19064.
Bill B
11-18-2003 04:42:59
As I understand it, the factory fiscal year started Nov first, so any tractor built on that date in 36 or until oct 31 37,would be a 37. So if your serial number show it to be a 36 then it should be grey. If it were built after nov first, it would be a 37. If I am wrong, Guy Fay will correct me.
Guy Fay
11-18-2003 04:55:40
 Re: Re: Farmall Red vs. Farmall Grey.... in reply to Bill B, 11-18-2003 04:42:59
I think you've got it right for the F-20s. I did a Red Power article that gave the PROBABLE first serial numbers of red tractors, since curiously, IH didn't always use the fiscal year as the serial year at that time-it was pretty flaky in the 1930s.
The Red Barron
11-18-2003 20:11:02
 Re: Re: Re: Farmall Red vs. Farmall Grey.... in reply to Guy Fay, 11-18-2003 04:55:40
Could you repost the numbers of the F12, F20 and F30 that began to be painted red? I would be greatful.
F-Dean
11-19-2003 07:37:15
 Re: Re: Re: Re: Farmall Red vs. Farmall Grey.... in reply to The Red Barron, 11-18-2003 20:11:02
According to an article in Red Power by Lee Grady, the first Red tractors were:
F-20 #FA-68749
F-30 #FB-19064
F-12 #FS-81837
I-12 #IS-1525
W-12 #WS-2768
O-12 #OS-2277
I-30 #IB-3099
Model 20 Industrial #IN-18405
IA-40 #IAC-525
ID-40 #IDC-521
W-30 #WB-15970
10-20 #KC-210235
WA/WK-40 #WKC-5197
Kerosene WA-40 #WKC-5135
WD-40 #WDC-5120
Zak
11-19-2003 06:14:06
Just for reference (as everyone knows that IH 2150 is the best red spray paint)...what to use for a grey match. The closest I have come to an original shade of gray in a commerically available spray paint is PLastikote 1006 Dark Gray. I buy it in autoparts stores (NAPA, etc). Great for those little touchup jobs (or entire tractors as I did!) -Zak-
F-Dean
11-19-2003 07:41:06
 Re: Re: Re: Re: Re: Farmall Red vs. Farmall Grey.. in reply to Zak, 11-19-2003 06:14:06
Van Sickle Paint in Lincoln, Nebraska make a McCormick-Deering Gray. It can be ordered in gallons and they will put a gallon in spray cans (14 cans) also.
Luke
11-22-2003 04:36:04
 Re: Re: Re: Re: Re: Re: Farmall Red vs. Farmall Gr in reply to F-Dean, 11-19-2003 07:41:06
thanks for the paint info Dean.
i guess as you guys pointed out earlier....my F12 should be gray.this one stays red.the next one,
will be a gray Farmall.we have a farm supply store here that sells Van Sickle too.thanks for the numbers also.
Luke
