H-4 magneto
matt Sheaffer
11-15-2003 11:49:47
My H-4 magneto dosen't have any spark at the points, I tuned it up. And it still dosen't have spark. Does that mean the magneto went bad, or could anything else be wrong? It has been spining over alot latlely, before it would start
Glen in TX
11-15-2003 21:14:05
 Re: H-4 magneto in reply to matt Sheaffer, 11-15-2003 11:49:47
You tuned it I presume with new clean, correctly set points and condenser. If you took the gears out of the gear case and didn't align the marks correctly it won't be in time and work correctly. The R mark on the dist. gear lines up with beveled tooth on small metal gear for a CW drive mag and L mark for a CCW mag. Could have a bad coil or bad wire from points to condenser. Replace wire or cover with heat shrink tubing. Check to make sure terminal under points cover isn't touching ground. Check for the brush in cap to be there and clean contacts in cap and on rotor or replace. Take off kill terminal wire to be sure that wire or switch isn't the problem. Try these simple things first. I can help with a look at it or other tests if needed. good luck.
Brad L
11-15-2003 16:18:36
Have you set the gap on the points correctly .013 to .020 will work. I think its .013 though. Did you check your condensor?If you measure it with an ohm meter it should move the meter a little bit while it charges and the will go back to an infinate reading.If you read nothing or a resistance constantly its bad.ALSO check points for pitting or corrosion.If none of that works it could be the coil in the mag itself.
