for hugh mackay
red cub
11-15-2003 05:39:08
when you say factory set up,what do mean by where is my cast wheel. both of my rear wheel centers are preesed steel.i have a cast wheel weight on each side.is my right side center sapposed to be different. i removed the front weights tomake it easier to steer, and bolted them to the draw bar for better traction,but i put them on front last night to see if makes differce. thanks for the help
Hugh MacKay
11-15-2003 23:39:33
 Re: for hugh mackay in reply to red cub , 11-15-2003 05:39:08
redcub: Scotty has already given you the right answer, All off set Farmalls came from factory with heavy cast wheel center for the right and pressed steel for the left. That was to balance tractor only, from there you add same weight to each side.
People do some funny things with offset tractors. Some guys will actually buy a wheel so they are both the same. I bought a Farmall 140 just about a year ago. They had the left wheels of tractor set at maximum tread and the right wheels at minamum tread, of course thinking they were balancing the tractor. Not only did they throw the tractors balance off badly. I bet it wouldn't pull more than 65% of one set properly. Inside of rear tires same distance from fender very important.
scotty
11-15-2003 06:56:53
Red Cub, Your cast wheel hub should be on your right as you sit in the seat. The cast weight is a counter balance for the offset tractor design.
scotty
