H steering linkage ?
Two Bit
10-31-2003 06:33:22
What is the proper part name of the small u-joint that connects the shaft from the steering wheel to the shaft going to the front bolster (near the area under hood where gauges are)? Mine is all worn out and has lots of play. I have found parts online described as "steering knuckle pivot outer bearing race" and "steering knuckle pivot inner bearing race". Are these the parts, and if I buy the pair will these parts totally rebuild my bad u-joint or do I need additional parts?
Red Man
10-31-2003 14:46:03
 Re: H steering linkage ? in reply to Two Bit, 10-31-2003 06:33:22
I got the parts, 4 cups and the yoke, @ Case IH for $9.00 and rebuilt the one on my SM. It took a hammer and a drift and a lot of persuasion.
bindernut
10-31-2003 08:31:40
If you need a u-joint, don't buy bearing races. they'll do you no good. Take the whole shaft to a good auto parts store. They will likely be able to get you a new u-joint. It'll be less than $20, and for 5 or 10 bucks, they'll probably put it in for ya. We do it at the parts store I work at in St. Louis.
