Brakes on an International 240-U
Jerry
10-18-2003 21:49:51
Does anyone have an idea on how deep the depression in the brake pedal for the adjustiong ball-nut is supposed to be? The brake pedals have no adjusment left on them, and when I apply the brakesthey go to within about a half inch of bottoming out before any type of brake resistance is felt.
I pulled the brake housing off, and I have plenty of brake pad on both discs on each wheel. I'm tempted to use a die, and continue the thraeds on up the adjusting rod. After looking at the depression in the brake pedal where the ball-nut rests, I got to wondering if maybe its worn out quite a ways?
If anyone has any ideas or suggestions I'd be happy to hear em. Thanx. Jerry
Ken
10-19-2003 14:07:21
 Re: Brakes on an International 240-U in reply to Jerry , 10-18-2003 21:49:51
When I got my 240U the brake rods both had thick washers on them that kept the round piece out of the pedal depression. I have good linings and brakes work fine. Would suggest the washer route is easier than deeper threads, but either should work fine.
ken
Don
10-20-2003 17:48:56
 Re: Re: Brakes on an International 240-U in reply to Ken, 10-19-2003 14:07:21
I don't have a 240-u but the IH brakes I have worked on have removable shims between the inner center casting and the outer brake casting. By removing them, it is like having thicker pads. Also I have had to replace the balls on both my IH and Case brakes. They actually wore. They were reasonable from the ih dealer.
Jerry
10-19-2003 22:48:41
Thanks for the heads up pon that Ken. Sounds like a better idea than threading the rod. I'll give it shot.
Jerry
