1066 overfill of trans
Skip H
10-13-2003 16:21:01
Seen the question on 1466 oil check and was wandering what diferance was noticed by overfilling the trans.I have a 1066 and always looking for ways to help her along.
Hugh MacKay
10-13-2003 22:56:32
 Re: 1066 overfill of trans in reply to Skip H, 10-13-2003 16:21:01
Skip: I always found my 656, 1066 and even 560 hydraulics worked better when about 1/2 over the full mark. With 560 was a bit more difficult to achive as you had to fill to level and add a gallon. It was that way from new, didn't need poor filter or loose pickup tube. If you started getting squacks from hydraulic system you knew it was getting down to full mark.
w gatewood
10-13-2003 19:23:41
you need the filter extention kit , it has a second filter and incresses the life capicity and by running the trans 5 gal over full it helps to keep the system from sucking air if the sump tupe has workes a little loose have ran all of our 06 , 56, and 66 and 86 series over full for years
Skip H
10-14-2003 17:14:42
 Re: Re: 1066 overfill of trans in reply to w gatewood, 10-13-2003 19:23:41
On my way to the shop to put some more oil in my trans.Tnanks
