300 Utility steering parts
justin
10-09-2003 18:26:42
Im looking for a place to buy the bearings and seals for a the manual steering unit on a 300 utility or if anyone has one i might buy a whole power steering setup for one. Thanks
justin
10-09-2003 18:33:11
 Re: 300 Utility steering parts in reply to justin, 10-09-2003 18:26:42
you should be able to get those parts thru your local case IH dealer
big fred
10-09-2003 21:09:37
 Re: Re: 300 Utility steering parts in reply to justin, 10-09-2003 18:33:11
I agree, I got them for my p/s unit a couple years ago, took them home and they were the wrong size. I found out that my P/S unit was for a 460U. If you decide to go with a replacement steering gearbox, a p/s unit out of a 300U and 350U are the same, and a 460U will bolt right up in the same place, though it's different internally. In addition, you will need to replace the regulator/safety/flow control valve with one from a p/s tractor, as you need priority flow to the p/s unit.
As I recall, the bearings and seals (the ones I hadda take back) weren't too expensive, probly around 20 bucks total for both sides.
