Mc Cormick 400
Greg H.
09-24-1999 13:12:37
I;m a JDman by nature, but I ran across a tractor yesterday setting along the road for sale, and I just gotta ask a question about it. It was obviously an International Harvester Product, but all it said on the sheet metal was McCormick, and 400. It looked alittle bigger than an M, had somewhat rusty, but very strait sheet metal. great 14.9 x 38 rears, and new like front tires on it's tricycle front. It had no fenders or three point, but it did have hydrolic remotes, independent PTO, Power steering. Ran good, although it had a gas motor that looked alittle dirty. the only thing the owner is reporting wrong is a short in the electrical system. He had the Positive unhooked prior to starting. What is this tractor worth, how much does it weigh, and what is it's horse power. The man is asking 1500. to me it seems reasonable. Even though I did feel out of place looking at it painted red and all It seemed to be a sound machine. Help me if you can. Thanks Greg H.
Harold H
09-25-1999 04:45:52
 Re: Mc Cormick 400 in reply to Greg H., 09-24-1999 13:12:37
Greg,
There is a McCormick International 400 that is a standard type tractor. The tractor you are looking at is a McCormick Farmall 400 which is a row crop tractor. If it is gasoline, it has a 264 cubic inch engine rated at 1450 rpm. It was tested in Nebraska test # 532 with 45.34 db hp and 50.78 belt hp. Corrected to sea level maximum hp is 47.34 db and 52.71 belt. It sounds like a very resonable offer.
Harold H
Farm-Al
09-24-1999 18:34:54
Greg H. The 400 was built from 1954 to 1956,it's about A 54 to 55HP tractor. The 400 has A live PTO, Power steering and A torque-amplfier which is A lower gear shift on the go setup. Hydra-touch live hydr. system. The tractor you mentioned may not have some of these features depending how it was spec.'d when it was ordered out of the factory. I guess the price don't sound too bad if it's A decent tractor...Good to hear A JD man looking at A Farmall!!!!! Al
RickB.
09-25-1999 13:58:20
 Re: Re: Mc Cormick 400 in reply to Farm-Al, 09-24-1999 18:34:54
400's were not offered with factory power steering. The 450 was the first offspring of the 'M' to feature P/S.
Harold H
09-25-1999 20:52:44
 Re: Re: Re: Mc Cormick 400 in reply to RickB., 09-25-1999 13:58:20
The 400 was available with power steering.
Harold H
John
09-24-1999 18:13:19
I think the 400 is basically a M with newer sheetmetal on it and some improvements to the engine.1500 sounds pretty good to me.
