560
Russell Montgom
08-13-2003 18:26:16
I was needing to find out how much I could expect to get for a 560. The rings are stuck, water pump needs to be replaced. Sheet metal is rough and needs back tires and oil bath filter is missing. I cleaned the gas tank and had the carb rebuilded but after I found out the rings were stuck and the water pump needed worked on i gave up. Thanks for the help Russell
dhermesc
08-14-2003 06:11:22
 Re: 560 in reply to Russell Montgomery, 08-13-2003 18:26:16
Hate to say it but I think your going to be lucky to get $300 to $500 out of it.
Nebraska cowman
08-13-2003 18:30:47
over haul will cost $1500 plus labor. $500 for parts, $500 to fix and paint, $700 for tires. Tractor shoul;d be worth around $3000 when you get done. Have fun, I'd pass.
