farmall super h all fuel
arthur
08-12-2003 15:16:52
how common is the super h all fuel tractor?
Guy Fay
08-12-2003 19:55:23
 Re: farmall super h all fuel in reply to arthur, 08-12-2003 15:16:52
Kerosene/Distallate Super Hs are very rare- on the Stage IIs, only something like 30-60 were built.
arthur
08-13-2003 07:53:28
 Re: Re: farmall super h all fuel in reply to Guy Fay, 08-12-2003 19:55:23
how can you tell if it is a kerosene/distallate?
Guy Fay
08-13-2003 15:11:39
 Re: Re: Re: farmall super h all fuel in reply to arthur, 08-13-2003 07:53:28
First off, there's no such thing as an all-fuel IH. "All-Fuel" was a Deere term. IH made kerosene or distillate tractors (they're actually slightly different).
How do you tell? The small gas starting tank under the hood (the extra little cap sticking through the hood- if the tank's gone, there's an extra hole). Different manifold with heat box (if it hasn't been replaced). Best way is the serial number suffix codes.
arthur
08-14-2003 12:59:11
 Re: Re: Re: Re: farmall super h all fuel in reply to Guy Fay, 08-13-2003 15:11:39
thanks for the help!!!!! !!!
CNKS
08-12-2003 18:17:05
All I can say is less common than the non-super letter series. Probably most of the early 40's were distillate or kerosene, relatively few post war. I doubt if it adds any value to it, if someone wants to actually use the tractor, it is a disadvantage because of less power.
