Farmall M High-Low Range
Laser
07-28-2003 16:22:04
I purchased a farmall M that has a serial number of 127755X1 which I believe is a 1947. It has a cable that enters the housing by the clutch and then enters the transmission. This cable shifts a high-low range. I have never seen this on another tractor like this before or since.
What does the X in the serial number mean?
How many tractors have this?
Russ
07-28-2003 19:28:39
 Re: Farmall M High-Low Range in reply to Laser, 07-28-2003 16:22:04
I have heard the M&W 2 speed also double the speed of the belly pump and the pto, if this is true you have to be careful!
Larry
07-28-2003 18:16:39
You have a M&W 9 speed transmission add on. The X1 in your serial number means a gas engine.
Laser
07-28-2003 18:22:22
 Re: Re: Farmall M High-Low Range in reply to Larry, 07-28-2003 18:16:39
This is a working high and low range in all 5 gears and reverse.Is this still the same?
CNKS
07-28-2003 19:10:49
 Re: Re: Re: Farmall M High-Low Range in reply to Laser, 07-28-2003 18:22:22
5th is direct drive, If 5th indeed has two ranges, you don't have an M&W.
