Farmall H steering gear replacement
OT Guy
07-23-2003 12:27:57
I have a 1945 H I'm currently working on. I noticed the steering was loose when running down the road in 5th gear. I pulled the cover off to remount the sector gear 180°, but found that someone at one time had already done this to the tractor. In fact, there wasn't a worn spot on the entire sector gear.
So I'm looking to replace the sector gear, and I have to figure to replace the worm gear also, seeing that the sector gear is so worn. I can't imagine the worm gear didn't wear. Anyway, does anyone carry these gears? And seals?
I appreciate all help. Thanks!
OTG
Haas
07-23-2003 17:39:31
 Re: Farmall H steering gear replacement in reply to OT Guy, 07-23-2003 12:27:57
Replacing these gears will be very expensive if you get new gears. I think you can still get them from IH. Have you checked the bushings and bearings which could be some of your problem. If the ball bearing one the end of the worm gear has any play or is not bolted up tight to the gear, you will have play in the steering. Also, the outer race of that bearing must be clamped tightly in the steering box by the big plug on the front.
OT Guy
07-26-2003 12:49:44
 Re: Re: Farmall H steering gear replacement in reply to Haas, 07-23-2003 17:39:31
I checked the bushings and bearings, they are tight and in good shape. I'll try my local dealer. Appreciate your help!
OTG
