Farmall H PTO shaft help
Chad
07-15-2003 10:26:54
I am buying a pto shaft for one of my implemtents today and for the life of me I forgot to look to see what size and how my splines the Farmall H has.
what exactly is it so i know what to buy! thanks
Chad
jal-SD
07-15-2003 11:21:10
 Re: Farmall H PTO shaft help in reply to Chad, 07-15-2003 10:26:54
Chad, early H's had a 1-1/8" spline, think they changed in '42 or so. Later ones had the 1-3/8, so depending on year of your H, it could have either one. I'd get the 1-3/8, its the most common, you can always get an adaptor to convert the 1-1/8 to 1-3/8. (My $0.02 worth. jal-SD)
Chad
07-15-2003 10:40:10
Is it 1-3/8" DIA 6 spline?
will a quick disconect style work ok?
thanks
Dave_D
07-15-2003 11:50:12
 Re: Re: Farmall H PTO shaft help in reply to Chad, 07-15-2003 10:40:10
Yep,
rustyfarmall
07-15-2003 11:01:22
They are all standard size, either 540 rpm., or 1000rpm. since I am sure your H does not 1000 rpm. p.t.o., it should not be too much of a problem finding a new shaft that will work, it will be the 6 spline.
Chad
07-15-2003 11:55:51
 Re: Re: Re: Farmall H PTO shaft help in reply to rustyfarmall, 07-15-2003 11:01:22
Thanks guys! it is a 44 H and if not I will use it on the 48 H. Dad measured and said it looks like it is 1-3/8" but then again he has measured for me before hahahahahahaha.
thanks for the help!
Chad
