Farmall 504 trouble
d finn
07-13-2003 04:43:01
Suggestions welcomed...
My 504 runs great on level ground, full throttle
or idle. As soon as I go up hill or engage equipment, it starts to sputter, then die.
Carb has been cleaned twice and seems to function fine. Could it be electrical? Thanks
here, try this
07-13-2003 04:54:21
 Re: farmall 504 trouble in reply to d finn, 07-13-2003 04:43:01
check the points
d finn
07-13-2003 07:13:47
 Re: Re: farmall 504 trouble in reply to here, try this, 07-13-2003 04:54:21
Points have been replaced to no avail...
could distributor fail when tractor is under load?
here, try this
07-13-2003 13:22:20
 Re: Re: Re: farmall 504 trouble in reply to d finn, 07-13-2003 07:13:47
ANYTHING is possible. found an M once with an extra long screw holding the condenser, and no, it wouldn't run that way. bad plugs will show up under load, as will poor wires, cracked cap, etc.
then on the other hand it could still be a fuel problem. kind'o hard to tell from here. Keep trying bud.
