Suggestions needed: jacking up the rear of a 130
Thomas Coughlin
07-06-2003 17:51:43
I will be changing tires on our 130. How best to jack up the rear end? The jacking pad on the axle is a lot higher than the reach of an average floor jack. I can do this without removing the wheel centers, right?
Hugh MacKay
07-06-2003 18:12:00
 Re: Suggestions needed: jacking up the rear of a in reply to Thomas Coughlin, 07-06-2003 17:51:43
Thomas: I always jack on the drawbar mounting plate on the standard drawbar. On the fast hitch tractors I jack under the forged steel mount for the fast hitch wish bome. If you are removing both sides at same time I always let the wheel center down on 2' long 6x6 blocks, after I've taken each wheel off. Just turn the center so it rests it's flat side on the block. That way tractor can't roll even with brakes off.
