Farmall H starting
Jim Daniels
06-23-2003 04:13:48
Have an H that is hard starting after doing some work. Must leave running to finish a job because I may never get going again untill next day. Carberator problems? Vapor lock? It does give a puff of black smoke when I start it in the morning.
Sid
06-24-2003 03:58:12
 Re: Farmall H starting in reply to Jim Daniels, 06-23-2003 04:13:48
If you have magneto ignition it will almost certainly be the coil. I had the same trouble with my H. If I stopped the engine when it was hot it I would invariably have to have a tow to get it started again. Fitting a new coil fixed the problem. Sid.
Bob M
06-23-2003 06:22:18
Jim - Sounds like an ignition problem to me. What may be happening is the coil output voltage drops off as the coil warms up in use. It'll have enough voltage to fire the plugs while starting up cold. However once it gets hot the coil can still fire the plugs when the battery is charging, but won't fire 'em under the low voltage system as when cranking. Most likely it's the coil itself. However it could also possibly be a failing condenser, badly worn/adjusted points. Dirty plugs/plugs gapped too wide could aggravate the situation.
One way to verify is try pull starting the tractor when it's hot. If it fires right up (one or two crank revolutions), it's ignition. However if the crank must spin many revolutions before it fires or it won't fire at all, then suspect a fuel problem
Incidentally it's unlikely to be vapor lock - gravity fuel systems are pretty much immune to that problem.
Tabor
06-25-2003 06:09:45
 Re: Re: Farmall H starting in reply to Bob M, 06-23-2003 06:22:18
I had the exact same problem with my 47H. I replaced the coil in the magneto. Fixed it right up starts like a champ hot or cold. Be sure when installing the new coil that you center it perfectly, if not it can cause irratic problems with your timing.
