Farmall trans noise
kem
06-22-2003 22:22:39
i just finished a farmall b..now trans is very noisy, the only things i changed where the gaskets and one bearing...the countershaft/bevel gear front bearing..it sounds like a ring gear noise....has anyone changed this bearing and had to re set up ring and pinion? i rebuilt a super av and had the exact same problem anyone have any ideas? thanks all..... .
Glenn(WV)
06-23-2003 06:13:19
 Re: farmall trans noise in reply to kem, 06-22-2003 22:22:39
A certain amount of gear noise is normal, as these tractors have straight-cut gears in them ... what are you using for gear lube?
ken
06-23-2003 10:37:09
 Re: Re: farmall trans noise in reply to Glenn(WV), 06-23-2003 06:13:19
has 140 wt. this is way louder then normal, and it did not do it before we took it apart.....
