International 300 utility question
Tim
06-18-2003 14:32:21
I'm splitting the tractor and the last thing left is the bolts holding the engine to the clutch housing.My question is;Is there bolts that go through the housing,or can i get them all from outside?
Aces
06-18-2003 17:15:59
 Re: International 300 utility question in reply to Tim, 06-18-2003 14:32:21
Should be 3 on each side from the front and 2 from the back into the back of the block under the tank none inside
Ernie Bob
06-18-2003 22:58:02
 Re: Re: International 300 utility question in reply to Aces, 06-18-2003 17:15:59
Tim,
You didn't say if you were going to seperate the TA from the Trans/Rearend. There is one bolt that you have to remove the plate on the bottom-rear of the TA housing that goes into the Trans/Rearend and is not seen until you remove the plate. I ruined a TA housing the hard way a few years back. Feel free to e-mail me if you have any questions, I've split mine quite a few times.
Good luck!
Ernie Bob
