560 WITH BELT PULLEY
Dave L
06-16-2003 10:00:46
How common is it for a 560 to have a belt pulley? I am looking for a replacment tractor. And would like to get one with belt power and live hyd.
JR40
10-10-2004 13:30:57
 Re: 560 WITH BELT PULLEY in reply to Dave L, 06-16-2003 10:00:46
Not very common probally due to age. we have a pulley and complete houseing and part tractor with hyd on it eveything but engine block and wide front end but have a decent narrow front all sheet metal in good shape with TA complete due have engine internals
Hugh MacKay
06-17-2003 03:22:40
Dave: I guess we are all assuming you are refering to side mount pulley as oposed to PTO mount. I think the only ones you can even consider are MTA, 400 and 450. I never had a pulley on my 560, however the plate you remove to install a pulley is full width of tractor chassis and that is probably 2-3 inches wider than chassis of 300, 350 or 460. I had a 300 with a pulley at same time, 300 is quite small through chassis compared to the larger chassis.
Diesel Breather
06-16-2003 18:48:36
Make sure you get on from a 560. The belt pulleys of a 460 and down have a different shape on the top of the casting. The reason is for the fuel tank clearence.
Colorado Curt
06-16-2003 10:20:26
I have not seen many 560s with a belt pulley. The drive unit from an H, M and the number series 300, 400 will bolt on.
rustyfarmall
06-16-2003 12:43:37
 Re: Re: 560 WITH BELT PULLEY in reply to Colorado Curt, 06-16-2003 10:20:26
A belt pully unit from an M or a 400-450 might fit, a unit for an H or 300-350 is smaller, and will not interchange with an M, or 400-450.
