Order Farmall Cub Parts Online
Compression / Vacuum question on a CUB .....
Glen
05-29-2003 15:32:19
My '52 Cub has started puffing a little bit of smoke (greyish in color). Plugs don't look wet (just a little bit of soft black soot). It's not using oil between changes. I checked the compression as follows: 100 pounds on 3 of the cylinders and about 102 on the fourth cylinder. Also, I ran the motor with a vacuum gauge attached and it read a very steady 17 & 1/2 inches.
Is it time for rings maybe ?
BIG JOHN
05-29-2003 19:18:56
 Re: Compression / Vacuum question on a CUB ..... in reply to Glen, 05-29-2003 15:32:19
Re-torque your head. You might be experiencing just a small amount of seep causing a puff of white/gray smoke when you start up.
Bus Driver
05-29-2003 17:00:18
No way would I consider rebuilding that engine at this time. Make sure the ignition and carburetion systems are in top conditon- and enjoy the tractor!
EZ
05-29-2003 15:38:06
I'd have to say your compression is pretty good, I wish mine was that high. I've only got 80 on mine. Maybe your gas is too rich, and you need to adjust the carb. How is your timing?
