Capacity of Farmall 560 Hydraulic reservoir
GreenHorn
05-12-2003 15:20:58
I need to know what the capacity of fluid is for my Farmall 560 . I also would like to know how difficult it is to change the hydraulic pump ? Thanks in advance .
PA Steve
05-13-2003 21:06:35
 Re: Capacity of Farmall 560 Hydraulic reservoir in reply to GreenHorn, 05-12-2003 15:20:58
Changing out the hydraulic pump is a bit of a job. You have to pull the top plate of the transmission case.
here, try this
05-12-2003 18:07:05
the 560 takes its oil from the transmission case so it holds about 14 gallons. you may want to change the filter. it is hiding under a flat plate on the right side about 8 or 10 3/8 cap screws
