'39 M clutch
Ed in IN
05-04-2003 16:49:12
I'm finally getting around to putting a clutch in the "M". Everything came apart fairly easy in just under 2 1/2 hours. Thanks for the tip about using allthread to let the hydraulic pump down. However, the pilot bearing carrier had come loose and will also have to be replaced. For some reason the two mounting bolts had come out and were on top of the hydraulic pump. What should be the fit between the end of the splined shaft into the pilot bearing? What should the new pilot bearing be packed with, since it is open on the side toward the engine? Thanks for the help.
