Farmall 200 Thermostat?????
Gomer
05-02-2003 21:30:43
Is my Farmall 200 supposed to have a thermostat??
I don't see where one would be located. Thanks for any help you can offer.
Hugh MacKay
05-03-2003 19:43:15
 Re: Farmall 200 Thermostat????? in reply to Gomer, 05-02-2003 21:30:43
Gomer: My Farmall 130 has a thermostat the size of inside diameter of hose, and an inch long section of pipe in hose. This pipe is positioned so it holds thermostst tight against neck from engine. I don't think that is the original setup. I suspect it is the work of a guy I had do the engine rebuild. It works and works well.
Stan(VA).
05-03-2003 05:24:18
It's in the upper water neck casting that bolts to the cylinder head. Casting also has the temperature gage sending unit. Remove the radiator hose and it should be held in by a sort of a snap ring arrangement, but most have been removed long ago with the groove for the retaining ring coroding away.
Stan(VA).
