F-20
Gil
04-27-2003 10:27:10
I cant see to find the serial number plate on a F-20, I recently purchased. Could someone tell me where to look? thanks.
Bill Smith
04-28-2003 21:43:58
 Re: F-20 in reply to Gil, 04-27-2003 10:27:10
Serial number plate should be on the back of tool box under gas tank. Sometimes the tool box is missing (fastens only with 2 or 4 bolts). Sometimes the tool box is there but plate is missing off of it (fastens only with 4 rivets). If plate is missing a serial number is stamped on left frame rail, and on right side of engine. On my 36 model all three numbers match. Not sure if they always matched, but even if not the frame rail or engine serial number would give you an idea on year. The number on the serial number plate would be the official number. Otherwise you can revert to casting code numbers on the bigger castings. The letter on the end indicates a year. Not sure what letter indicates what year myself.
F20II
04-27-2003 10:40:41
Look on the left side on tool boc under gas tank, if not there look on left front frame rail, if not there see if you can find a casting number on engine, wheels or rear housing, then post casting number on the list or email me we can figure it out between all on the board :o)
