B414 IH
gerald
04-26-2003 16:14:20
Could some one send me the specs on this tractor.
I mainly need the valve lash but would like the hyd presure and any thing else about it?
Fabien
04-30-2003 08:19:19
 Re: B414 IH in reply to gerald, 04-26-2003 16:14:20
slowly bu surely!
I&T shop manual specs for B414 gas:
firing order 1342
valve tappet gap (hot) .020 (in. &exh)
breaker contact gap .o14
distributor timing 5 degrees btdc
timing mark on crankshaft pulley
spark plug electrode gap .024
hydraulic pressure 2300-2400 psi, with 1250 pounds of weight on 3pt hitch. draft control(oustide) LEVER IS SET to the deepest (full forward ) position and speed control knob in the slow lift position.
let me know if you need more details
Fabien
Fabien
04-27-2003 17:28:21
I've got an IT service manual for my 1969B414Diesel. Give me more details,ie gas or diesel engine, then I can send you some appropriate specs. I'm looking to build a ROPS for mine. Is your tractor equipped with one?
Gerald
04-28-2003 16:20:18
 Re: Re: B414 IH in reply to Fabien, 04-27-2003 17:28:21
Thanks for answering I should have mentioned it is gas and no it is not rops equipped. I just bought its been a minature nightmare steering brakes head gasket hydraulics. Its finally starting to come my way!!
Shawn in MN
04-27-2003 08:23:50
I have a gas B414, yours is probably a diesel right? If you go to www.redpowermagazine.com/ and go to links, they have a web sight for UK red, they might be able to help you in their discussion forum. Good luck..... .Shawn
Gerald
04-28-2003 16:27:59
 Re: Re: B414 IH in reply to Shawn in MN, 04-27-2003 08:23:50
Thanks for ansewering mine is gas. I checked out the site you suggested a lot of good stuff but still didn't find what I was after.
