Got my A! (and I already have a question)
Glenn Reid in C
03-24-2003 21:35:43
I just brought home my new Farmall A and I'm pretty excited about it. They're so little and cute :-)
The headlights don't work, which is no big deal, but I'd like to hook them up. I don't see a switch anywhere. How are these "supposed" to be wired? Are they in the loop with the on/off ignition switch, or on a separate switch (which I would think better). Any info would be appreciated.
Glenn
jal-SD
03-25-2003 06:14:20
 Re: Got my A! (and I already have a question) in reply to Glenn Reid in CA, 03-24-2003 21:35:43
Good looking A. I hope to have one like it someday. I think I have a spare light switch off an older H if you need one. They are the same as what was on the A's & B's. (My $0.02 worth. jal-SD)
gene b
03-25-2003 04:09:40
On the oval shaped housing that is below the throttle there should be an AMMETER and a dial that rotates clockwise. The knob has four positions full counter-clockwise is the regular charge position the next click is for high charge the next click is for dim lites ant the last one is for brite lites. If you will get an owners manual it will have the wiring dia for the different systems as there were some different types of charging and lite systems. Yours appears to have the most common type with a cutout on the generator and should be positive ground. These were good systems and work well i have 11 A and Bs all are original types and no trouble. Good choice these are neat little tractors glad to help anytime just e-mail gene b
Dave_G
03-24-2003 21:48:31
Punch the link below, it is one of Bob M's online diagrams.
Good Luck
http://albums.photo.epson.com/j/ViewPhoto?u=4001561&a=30065733&p=60246204&f=0
