Final drive housing bolts
greatflake
03-21-2003 14:56:55
Maybe someone other than me has this problem...
The final drieve housing bolts keep loosening up on me.. its just the right side, when sitting on the tractor, i can tell when they've backed out due to the way that she pulls when i stop and start. i know that i've got one stripped out, should i just stick some lock tite on em and go with it or is there some possible hidden cause.
any ideas would be gratefully recieved..
Hugh MacKay
03-22-2003 02:39:23
 Re: final drive housing bolts in reply to greatflake, 03-21-2003 14:56:55
The others are right, all I am going to tell you is stop using until you get it fixed. Those little offsets may not seem like a bundle of hp, however they do have the ability to break that casting even when it is tight.
asj
03-21-2003 20:49:00
There should also be to dowel pins to keep it from moving. If they are missing bolts will tend to loosen up.
CNKS
03-21-2003 19:03:56
There's no hidden cause. At the least you should get a tap and see if you can fix the threads. Otherwise, you can probably use helicoils. But, I've never heard of using them in that situation. You probably have damage to other threads in addition to the one you mentioned.
On What Model?
03-21-2003 16:52:10
What model tractor are you having this trouble on?
great flake
03-21-2003 19:04:45
 Re: Re: final drive housing bolts in reply to On What Model?, 03-21-2003 16:52:10
after reading my post i feel stupid i didnt put it in that its on a 45 A sorry...
