Sizzling noise
greatflake
03-18-2003 15:31:42
Guys i need some help here.. yesterday i used my 45 A to get some equipment off the trailer and when i went to restart it i got a sizzling noise from the starter.. seems to be coming from the solenoid..tried it when it was kinna dark and the battery cable end started to glow a little..is it time for a new starter or can i just get by with the solenoid if i can find one? or any other ideas?
Rick P
03-20-2003 04:56:01
 Re: sizzling noise in reply to greatflake, 03-18-2003 15:31:42
My H starter locks once in awhile put in 5th rock back and forth you will hear it come loose. Rick P
here, try this
03-18-2003 17:55:38
just seems like a bad connection to me
gene b
03-18-2003 16:26:00
There should not be a solenoid on a 45-A You must have the starter locked up. Unbolt the starter an check to see that the starter drive isnt locked on the ring gear. The post should never glow or even sizzle if it does something bad is happening.
great flake
03-18-2003 17:47:30
 Re: Re: sizzling noise in reply to gene b, 03-18-2003 16:26:00
your right its not really a solenoid. i wasn't sure of how to describe it. thanks for the advice, i'll try it in the morning
Hugh MacKay
03-19-2003 03:51:49
 Re: Re: Re: sizzling noise in reply to great flake, 03-18-2003 17:47:30
geneb is probably right on starter lock up on ring gear, Paul could also be right and your starter is toast. There is no doubt you have a bad battery connection also and indeed that could be source of your problem. The bad battery connections often cause the starter lock ups. It can also be normal wear on starter drive and ring gear reaching the rebuild point.
Battery cables and connections often overlooked. I started my Farmall Super A couple days back, only the 3rd time since last fall. Started great. After I had it running awhile I shut it down and in looking it over cables and connections are bad. I removed battery and cables to clean things up. The ten year old battery is staying but the cables and connections will all be new when it goes back together. $15. is a cheap fix, and good voltage and amps are the life of both battery and starter.
greatflake
03-19-2003 16:08:01
 Re: Re: Re: Re: sizzling noise in reply to Hugh MacKay, 03-19-2003 03:51:49
Thanks for the advice geneb, musta been what it was. pulled it, spun er' one time and bolted er back up and she roared to life.. ya probably saved me a few $. knowing me id'a put a new starter on her and been giving some free money!
Paul Shuler
03-18-2003 16:00:05
My Super C did this about 2 years ago. On the third try it smoked the pos. batt cable. Starter had gone bad. Had to get it rebuilt.Fixed my problem.
