C 135 engine tune up specs
Ted
03-08-2003 16:07:18
I have a 1947 Farmall A that has a C 135 engine from a newer model (I was told it came from a Farmall 140, but from what I have found, the C 135 was used in the 330 and 340 models.)
I see tune up specs on this site for all the letter series Farmalls, but none for the C 135 engine.
Anybody have or know where I can find this info?
TIA
Ted
Gary-Miss
03-08-2003 16:59:20
 Re: C 135 engine tune up specs in reply to Ted, 03-08-2003 16:07:18
Specs should be the same as a C-113 DISTRIBUTOR engine. (.020 on the points, >032 on the plugs. Most of te manuals will tell you .023 on the plugs. This has to be a misprint, cause I can't get one to run at .023 on the plugs. With the C135 engine, there should be a mark at TDC on the fron pulley with a pointer. Set it one there on compression, set the points properly, then loosen the distributor, rotate in IN THE DIRECTION of rotation until the points close, then turn the switch on an rotate it AGAINST the rotation until the points fire.Lock it down. You may have to do this a few times to get it right. If you have a test light, leave the switch off, connect the clit to the battery source, touch the wire going to the points, kit will light up. At the moment the light goes out (th points open, lock them down.
