'43M hydraulics again
IowayBoy
01-24-2003 16:10:32
Thanks again Steven@nd for input.Still not off.Movement was just top of timing gear cover.Pump stuck to it pretty good.Gonna put heat lamp on it,seeif gasket and goop will soften up,then see if litle jack between frame and pump will get it tmove alttle.(Gently,I know,I don't wan't to break it.
Steven@nd
01-24-2003 17:18:48
 Re: '43M hydraulics again in reply to IowayBoy, 01-24-2003 16:10:32
Somebody must have put some really sticky goop on that gasket! I am working on a W-9 and had to remove the head, wouldn't budge. I usually just lift them off with the cherry picker, no problem. Well, on the W-9 I lifted the hole front of the tractor off the ground and had to use an air chisel - still didn't move so I let it sit overnight (front of the tractor in the air). Came out the next morning and chiseled some more and it finally came.
If you have a paint scraper or some other thin object with a sharp edge to tap around where it is stuck it could help. Good luck, patience.
IowayBoy
01-24-2003 17:46:13
 Re: Re: '43M hydraulics again in reply to Steven@nd, 01-24-2003 17:18:48
Well,it has been colder than a teacher's wit here.That don't help.Will let yous know when successful.
