International 674 wont start or stop
Matt Danhauer
01-06-2003 14:49:31
my 674 motor(gas)just got overhauled but now it takes forever to get it to run and once it runs it disels until i have to kill it. the mechanic that overhauled it keeps working on it but still hasnt figured it out. it used to always stop and start until it got overhauled because it used oil. what the heck is wrong
Gordon
01-06-2003 18:14:58
 Re: international 674 wont start or stop in reply to Matt Danhauer, 01-06-2003 14:49:31
Check the timeing and check to see if the spark plugs are to hot. If they are not to hot I still would try colder ones.Chech if the engine is running lean a gasket could do that also.
Ken T.
01-06-2003 17:11:17
Could it be that the valve timing is a little bit off or that there is not enough valve lash so the valves cannot seat fully?
TL
01-06-2003 15:51:55
Our gas 674 did the same thing,hard to start then dieseled alot.Ours turned out being the intake gasket was not sealing at all.We put a new one in and it took care of it.
