Dwell setting for Farmall H
Ardie
12-23-2002 14:45:44
What is the dwell setting for a 1950 Farmall H?
Wayen Swenson
12-23-2002 19:38:48
 Re: Dwell setting for Farmall H in reply to Ardie, 12-23-2002 14:45:44
A bit of information for anyone who is interested.
To determine dwell for an engine, divide the degrees of a circle by the # of cylinders. (360 / 6 = 60) for example. Then multiply the answer by 2/3. In the case of the example 6 cylinder engine, the dwell will be 40 degrees.
An 8 cylinder engine has a dwell of 30 degrees and a 4 cylinder engine should have a dwell of 60 degrees.
Dwell is the amount of time (expressed in degrees of distributor rotation) that the points are closed allowing electricity to build magnetism in the coil which then produces the spark at the instant the points open.
This is a long answer for a simple question, but who ever said things were simple??
john d
12-24-2002 12:48:47
 Re: Re: Dwell setting for Farmall H in reply to Wayen Swenson, 12-23-2002 19:38:48
Wayne's on target with the dwell information. And our buddy down the list aways is probably correct in saying that IH didn't bother to specify a dwell reading. He wasn't very tactful in the way he said it, however.... Dwell meters weren't all that common back in the '40s, and that type of distributor is not one of the easiest to set using a dwell meter. It is however, a useful tool for checking to see if your skills with a feeler gauge are as good as they used to be. For those not used to using a feeler gauge, remember to keep it CLEAN when setting the points.
Ardie
12-24-2002 09:49:54
I want to thank everybody for the follow-up replies, a lot of good comments.
CD
12-23-2002 16:28:43
Ardie,as the gentleman was trying to explain (BEFORE) taking his Ritalin pill is that these machines are not like trying to tune a 68'Z28 or a 70' Superbird 426 Hemi. Just use have someone turn the crank till the lowest point of the dist cam is lined up with the points and simply gap it with a fealer gauge to .0020" These machines are way to robust to ever need a precise Dwell meter check. good luck and Merry Christmas
CNKS
12-23-2002 18:27:47
 Re: Re: Dwell setting for Farmall H in reply to CD, 12-23-2002 16:28:43
Forgive me if I misread your post, but points are set on the high side of the cam, as this gives the maximum opening. The correct gap is .020, you put in an extra 0.
CD
12-23-2002 19:25:14
 Re: Re: Re: Dwell setting for Farmall H in reply to CNKS, 12-23-2002 18:27:47
Thanks for the correction. I guess I need to lay off the eggnog before giving advice!!
CD
12-23-2002 19:20:34
Yes sir TWO Tousanths is rather thort of twenty Thousanths!!HAha Darned extra 0!!
Joe Cow
12-23-2002 16:11:14
Every now and again you will have one that will twist OFF.
TO THE POINT
12-23-2002 15:21:24
On the dist,point gap..... ..o.20
Onthe mag ,point gap..... ...0.13
ALL my years of working on these tractors,I never read or seen were IH said there were DWELL settings for theses,all you HOT shot tractor guys you dont know JACK*&%# I own the O.E.M. books that I received from all my years working on them.
KURT
12-24-2002 06:26:40
 Re: Re: Dwell setting for Farmall H in reply to TO THE POINT, 12-23-2002 15:21:24
Whoa there big fella....
The Undertaker
12-24-2002 04:31:18
Mr. Point!
Having lived beyond three quarters of a century I had assumed I come to know a little bit about somethings. Now you've made me feel very humble, and convinced me I don't know anything about anything? On behalf of myself, and probably others as well, I want to thank you for saving us from ignorance.
"TU"
bill b va
12-23-2002 18:39:20
.20 = (200 thousants ) = 1/5 0f an inch or nearly 1/4 inch ( a big point gap ) i think you meant .020 (20 thousants )
CNKS
12-23-2002 18:32:50
Hey there TO THE POINT, you must have awfully thick feeler gauges and one heck of a spark if you can get them to run with settings of 0.13 and 0.20!
Steven@nd
12-23-2002 16:16:49
Actually, I believe that dwell would be a more accurate way to set the points. But hey, you're supposed to be the genius.
Nice to see someone else can take over answering questions, since I have been informed I don't know what I'm talking about lately.
Roy
12-24-2002 07:48:27
 Re: Re: Re: Dwell setting for Farmall H in reply to Steven@nd, 12-23-2002 16:16:49
Message for Steve, You better not stop posting. I'm almost 3 times your age, but I learn a lot from you and everyone else. I don't even own an H, but I still enjoy reading about them. Hopefully, in the next few years I will be able to get one. For now, I am getting ready to replace the seals, etc. in the back end of my B. Wish I could get you, Scottyny, The Red and some of the others to spend a few days here in Illinois. Maybe I could get it done right.
gene b
12-25-2002 05:19:37
 Re: Re: Re: Re: Dwell setting for Farmall H in reply to Roy, 12-24-2002 07:48:27
Where in the great state of ILL do you live?
Roy
12-26-2002 04:30:50
 Re: Re: Re: Re: Re: Dwell setting for Farmall H in reply to gene b, 12-25-2002 05:19:37
Gene B,
I live 12 miles west of Bloomington, how about you? We had about 4 inches of snow, making for a white Christmas.
Roy
12-26-2002 04:28:40
Gene B, I live about 12 miles west of Bloomington, how about you?
GRM Blow-By,Hy-Tech
12-24-2002 07:02:14
Steve, Being a new owner of an "49 H". I have been in this website everyday(4 months) learning alot about my H. Oh I have seen alot of "blow-by" in here!!!and some "Hy-tech" 8-letter words too. But Steve you ARE one of the guys I read your info 1st so can make some sense from the others!! "Don't bale on me know!!Hee Hee I gota long way to catch-up to you and your H. Thanks to you and others I think my "H" is in good hands. Just my $0.25 worth. Happy holidays to you and the rest!
CD
12-23-2002 16:36:25
As I was taught in the Military,Advice and ideas can come from all directions even from the bottom of the totum pole. It takes a smart man to know when to use it.Thanks Merry Christmas
The Red
12-23-2002 15:44:57
Your first two lines of information were informative. The rest was garbage and not in the spirit of the Farmall forum.
Paul
12-23-2002 17:25:02
 Re: Re: Re: Dwell setting for Farmall H in reply to The Red, 12-23-2002 15:44:57
Well said, Red. Lets not let sarcasm or cynicism deter people from asking or answering questions. We ALL can learn from these forums, no matter how trivial some questions, or answers may seem.
ScottyNY
12-23-2002 15:30:30
Easy, there!
Ron in Az
12-24-2002 10:15:13
 Re: Re: Re: Dwell setting for Farmall H in reply to ScottyNY, 12-23-2002 15:30:30
Hey Steven I know how you feel as about a year a go I was given grief when I was talking about the first pull on a sled With my new old H and didn't chose the right gear and did do poorly. mind you I didn't know I had one cylinder almost dead and had a brain attack stroke recently. Or I had not been on a tractor for over 30 years and did not remember of much from back on the farm. I recall you had some nice things to say. One other comment would be you will make one fine teacher at your young age you have a wealth of knowlge and skills and probably forget more about tractors that I will ever remember or can learn. So my words of wisdom Screw them and keep posting I ned the info. Thanks your friend Ron in Az... Merry Christmas and Happy New Year
