Farmall M power
Green Envy
10-21-2002 16:19:04
I have picked up a 3 bottom IH mold board plow. My question is. Can our Farmall M pull it about 4 inches deep in wheat stubble? I haven't restored the plow so I have not yet had a chance to find out. If it can't then I will use our JD D which I really don't want to. I like to have IH implements matched up with IH tractors and JD implements matched up with JD tractors for show.
Don LC
10-22-2002 09:19:49
 Re: Farmall M power in reply to Green Envy, 10-21-2002 16:19:04
It will pull it 8" deep in second gear maybe in third.....
joe
10-21-2002 18:00:48
it will pull it just fine. I use our 400 (upgraded M) to pull 3-16's 8 inches breaking 30 year-old clay sod. 4 inches in nice wheat stubble should be no problem at all. You may even want to run a bit deeper.
aaron
10-21-2002 17:20:27
Yes,
The M was rated as a three plow tractor and should have no problem at that depth. If you are new to the M's. You will find they have a surprising amt of power. I primarily use my M for pulling trees(roots and all).
PatM
10-21-2002 17:06:07
I would think it would walk away with the plow.
Dick Davis
10-22-2002 02:25:51
 Re: Re: Farmall M power in reply to PatM, 10-21-2002 17:06:07
Run away with
steve (ontario)
10-22-2002 10:43:42
 Re: Re: Re: Farmall M power in reply to Dick Davis, 10-22-2002 02:25:51
A good runnin "M" will pull a house down!!
