McCormick Deering 10-20 Serial Numbers?
Greg Anderson (
10-18-2002 18:44:38
Hi All,
I just acquired my grandfathers McCormick Deering 10-20 and was wondering if anyone could tell me where the tractor's serial number might be located? I have no clue as to the year of production. I see several numbers such as 835D on the transmission, 437 (D or B)-A on the engine block, 831D on the differential, 829DA on the gear box, 447DB on the manifold. Are any of these it? Thank you for your help.
Greg
Dave 1020
10-19-2002 12:52:05
 Re: McCormick Deering 10-20 Serial Numbers? in reply to Greg Anderson (TX), 10-18-2002 18:44:38
The ser #tag is under the gas tank.Then you have the # on the block.There is a casting # on the under side of the trans. that will give you the year.That # can be a year off.
Milton
10-19-2002 07:31:00
Hello Greg, ----- 19 / Oct. / 2002 -----
The PREFIX LETTERS for the McCormick Deering 10-20 are as follows; KC / NC / or NT. If there no serial number plate, then you would have to go to the SERIAL NUMBER on the motor / it is a raised smooth area - about 1/4 inch / and 3/4 inch by 2 and 1/2 inchs long. The motor serial number would be the same as the chassis serial number (if the motor has not been changed). The PREFIX LETTERS (on motor) would be; KCM / NCM / or NTM. The grease and paint would have to be removed to see the machined stamp Serial Number.
Regards, Milton
Redtractorman
10-18-2002 18:51:25
Should be on a plate on the fuel tank support,if you get the # I can tellyou the year.
