Farmall M Live Hydraulics
David
10-15-2002 21:37:22
I have recently purchased a a 1946 "M". It's a great tractor but I have to have live hydraulics. The hydraulics on the tractor work good and I would like to leave that system intact.
First question, can I find a salvage tractor with a live hydraulic system on it and put that system on my tractor while keeping my system completely intact? How much would a "system" cost me and how hard are they to find?
I understand that I have to mount a pump in the area of the Magneto by way of an adapter plate off of a later model tractor. Do they make new pumps off the shelf that will bolt up to this mounting?
If I leave the other system in tact, will I have to have a resivor for the new system? How many gallons does this need to be to power most modern acessories?.
George Mikesell
09-11-2004 15:09:19
 Re: Farmall M Live Hydraulics in reply to David, 10-15-2002 21:37:22
I have a M and H which I have converted to live hydraulics. I like to mount the pump at the dist. or mag. Would advise using heavier timing gears, but have gotten by with the originals, but I only use them to disc and mow, no loader. You can plum into the belly pump wich I did on M or make resivor, which I did on H. The resivor does not have to be laarge normally a gallon is plenty. If you are using the hydraulics hard and in hot weather would go larger. I have done belt drives and chains, really prefer dist drive, lot cleaner and simple.
BIG JOHN
10-16-2002 09:17:34
Tried to buy a parts tractor (SH) for the hydraulics a couple of weeks ago. Engine was disassembled and missing parts, wheels and tries were trash, tin wasn't good. Went for $425. To much for me.
Ty
10-16-2002 05:37:30
My 49 M that I got in July had add on hyd. It has a pump by the dist. The past owner said it was about $400 for it. I have a 4 gal res. where the old liftall was. It sticks down pretty far but works good. People said that you need stronger timing gears to handle the extra load.
Dick Davis
10-16-2002 06:04:19
 Re: Re: Farmall M Live Hydraulics in reply to Ty, 10-16-2002 05:37:30
Have a neighbor that added a hydralic system run by a roller chain from a gear added ahead of the crank pulley. He did an excellent job of tucking the pump up under the engine rails and protected by a massive mounting frame. He added an "L" shaped tank that holds about 15 gals of hydraulic fluid. The whole rig is very professionally done. His is a construction tractor and does exactly what he wants it to do. Good luck with your project. Dick
