M gas tank sediment bowl threads
Gordon{Tx}
10-08-2002 08:02:45
Removed the old sediment bowl from my tank, to install the new one. The threads inside the fitting of the tank, have been buggered up pretty bad at some point in the past. It wasn't leaking before. I'm thinking of putting some kind of thread sealer on the new one & putting it back. Give me some thoughts on this, & maybe recommend some sealers. Just don't want it to leak & ruin my new paint job. Thanks Gordon
Bob in SE Nebraska
10-08-2002 08:09:38
 Re: M gas tank sediment bowl threads in reply to Gordon{Tx}, 10-08-2002 08:02:45
I have had good luck by placing a good amount of teflon tape on the threads. If it will screw on at all, the teflon tape will probably take care of it.
Bob
Gordon {Tx}
10-08-2002 12:16:28
 Re: Re: M gas tank sediment bowl threads in reply to Bob in SE Nebraska, 10-08-2002 08:09:38
Thanks Bob I got it fixed.
Dave_Id
10-08-2002 08:16:38
Run a 3/8 npt die for the thread, and clean it up before reinstalling with the nylon tape....on problem threads, sometimes I use nylon tape on the OD thread, and pipe goo on the ID... every bit helps, I figure
Gordon{Tx}
10-08-2002 12:18:43
 Re: Re: Re: M gas tank sediment bowl threads in reply to Dave_Id, 10-08-2002 08:16:38
Thanks Dave I ran a tap through & cleaned em up. Then taped & doped it good & works like a charm.
