350 Runs but misses
Update
Gill
08-23-1999 04:59:58
Finally found the problem - the valves clearances were all out of adjustment. One push rod had come off, leaving an exhaust valve not functioning. The lock nut had come loose and fallen off, fortunately was still sitting on the block, had not fallen down in the motor. Was able to readjust clearances,now it runs like a top again. Thanks to everyone for your suggestions!
Blayne Mulanax
06-29-2000 20:34:20
 Re: 350 Runs but misses - Update in reply to Gill, 08-23-1999 04:59:58
My 350 isnt running yet because I cant decide what kind of intake and cam i should use with the twisted wedge Trickflow alum heads. If anyone has any ideas please let me know.
Phil Auten
08-24-1999 13:21:37
Great work Gill! Now it's Miller Time!
Phil
Village Blacksmith
08-23-1999 17:54:34
As you struggle with machinery, you will find that the little things are the most common and easiest to repair. Big problems are just a collection of small problems neglected.
The Red. Ditto!
08-24-1999 03:09:07
 Re: Re: 350 Runs but misses - Update in reply to Village Blacksmith, 08-23-1999 17:54:34
Corey's H was a classic of a whole lot of little things needing fixed piling up on one tractor. About everything I fixed on it I had done before but spread out over 3 Hs and 2 Ms. The engine rebuild was about the only thing I had not done before.
The Red
08-23-1999 05:17:46
Glad to hear the good news Gill!
