Farmall H
Lloyd
09-30-2002 10:49:51
wondering what spark plug works best. I wnat to replace the champion plugs,2 d18y and 2 d21 in her now,starts a little hard, and they seem a little dark, maybe she is a little rich-any suggestions???? Nice motor-no smoke.
thank you,Lloyd
Aaron
09-30-2002 19:34:34
 Re: Farmall H in reply to Lloyd, 09-30-2002 10:49:51
Oops,
Last week I just put champions in my newly rebuilt farmall M engine and Autolites in my piece of sh** ford truck! ...Doh!
Ron
09-30-2002 20:51:15
 Re: Re: Farmall H in reply to Aaron, 09-30-2002 19:34:34
If you had a Ford diesel You wouldn't have spark plug problems and it wouldn't be a POS tee hee LOL
randy hall
09-30-2002 16:52:18
we have a bunch of these old tractors. i use autolite 3116 in all of them, including the ones that we pull, good luck randy
Charlie
09-30-2002 14:29:16
This is an interesting discussion as I have D21 plugs in my H, M and 300U and I haven't had any problems. I had to put Champions back into my F14 as the AC sparkplugs I put in that a few years ago made starting a nightmare. Went back to the W14's and it starts right up.
Bob, Nor. Mn
09-30-2002 13:19:50
You can't go wrong with AC-C86, Both my "H"and "M" had Champs in them when I bought them,I think the reason that they were sold was because they would barely run. 9 yrs now on same plugs and run as new. Both use no oil.These are working tractors.----Have a good day.
SuperCmore
09-30-2002 13:09:21
Throw those champions away!! Put in Autolite 3116 or 3117..had Champions in my F-20..new ones..wouldn't even start!! Put Autolites in and she runs like new!!! Also have Autolites in my Super C....Cmore
AceS
09-30-2002 12:41:56
The Champion D18Y and D21 should never been put in the old 4 cylinder IH engines that is why they don't work good, see tractors that would not even start with these plugs in them.I always use UD16 in the 4 cylinders or a d16. May be champions are not as good as use to be but the D18y never worked good in the old tractors.
The Red
09-30-2002 11:10:17
I have given up on Champions. I've been using AC C86 and have had super luck with them. They are equivalent to the Champion D21 in heat range.
Loren Pribyl
09-30-2002 11:02:53
From what I've read, Autolite 3116 are probably the best. I just bought some for my M, because I keep having problems with the Champions fouling out. You can order Autolites from Brillman Company at>Link
I've had a lot of carbon build-up on the plugs in the M. I think it may be too rich on gas also, since it doesn't seem to be burning oil. With the Champion plugs, the tractor eventually starts to miss, and when I pull the plugs out and check for spark, they all fire OK, but they seem like they don't fire under compression because it runs good if I change the plugs.
Lloyd
09-30-2002 11:45:05
 Re: Re: Farmall H in reply to Loren Pribyl, 09-30-2002 11:02:53
I have the same experinece.I have 2 h tractors,one has new motor and can't keep the champ plugs in it. The other runs so good,and the plugs dont last there either,I can't wait to try someting new.
