H tire pressures
Mike ISW
09-21-2002 15:32:46
Maybe a dumb question but i'm wondering what some of you fellas are running for pressures in your tires. I've got an H with 5.50-16 fronts and 11.2-38 on the rear. I haven't checked to see what they are at yet but the fronts look low. Thanks for any comments! RED POWER!!!!!
joe
09-21-2002 19:17:12
 Re: H tire pressures in reply to Mike ISW, 09-21-2002 15:32:46
Front tires, I sometimes run as high as 45 psi when using loaders, pickers, cultivators, etc, but when not under much load, then a bit lower will do.
As for the rears, I always run them at 16, and then for plowing, run the furrow wheel at 18 and the land wheel at 14.
CNKS
09-21-2002 17:21:17
I usually just add air until they no longer bulge. Actually, 30 psi front and 14-18 rear is ok. I assume they are bias ply.
