Compression on A
glenshoe
09-03-2002 15:36:30
After being told that I "probably" have low compression on my 1945 Farmall "A", I finally decided to check it myself. Bought a compression gauge and the four cylinders come out as 80, 80, 85, 80 and the second time came out as 82, 84, 90, 80. Does this sound okay or am I in trouble?
glenshoe
09-04-2002 16:39:02
 Re: Compression on A in reply to glenshoe, 09-03-2002 15:36:30
In answer to your questions: The problem is that it won't start using the starter or by hand cranking. However, I can pull it and start it and it runs beautifully. Several oldtimers have told me this is a symptom of low compression but another has indicated timing, points, or maybe the condenser. The magneto generates a fairly spark. Any other ideas or should I concentrate on the above? Thanks for the responses.
gene b
09-04-2002 01:14:52
doesent sound all that bad if the engine still has the all fuel pistons in the compression is only 4.5 to 1 lots of them running around with comp in your range change oil put some new plugs in and go unless you are entering a pulling contest
johnny
09-03-2002 22:15:15
the A has 5.3 to 1 compression ratio and the supper A has6.0 they are low copression motors to start with 80psi is good you did not state problem your having
lc
09-03-2002 18:32:22
How many times around do you crank it to get each reading?
Red Dave
09-03-2002 16:30:06
Normal would be 95# to 100# so you are a little low, but I think it should run and they are within 10% of each other. Does it have much blowby coming out the breather when you run it?
