Farmall 460 Carb Problem
Ash
09-02-2002 19:41:13
I own a Farmall 460 that has a hard time pulling under a heavy load. It seems to be running lean because I pull the choke out and it helps. I don't think it has the oringinal carb on it. What was the original carb? I have cleaned and rebuilt the carb, cleaned fuel tank and filters, replaced points, condeser, rotor, cap, intake/exhaust manifold gasket, spark plugs, battery, plug wires, checked compression and that was good. Is a 3 bottom plow too much for this tractor? Where can I get used parts for this tractor (carb and generator)?
joe
09-03-2002 04:41:00
 Re: Farmall 460 Carb Problem in reply to Ash, 09-02-2002 19:41:13
I am not sure about the other stuff, but a 3-bottom is just about perfect for a 460. In REALLY good going, you could MAYBE use a 4-bottom, but 3-14 or 3-16 will work fine. Also, plowing about 6-8 inches deep will do just fine, don't try to do nine or ten, the tractor just won't pull it.
LeRoy
09-03-2002 12:45:46
 Re: Re: Farmall 460 Carb Problem in reply to joe, 09-03-2002 04:41:00
I think the 460 was rated as a 4 - 14 plow tractor.
Should pull the 3 bottom.
