Weight of front end of wide front model A international
Gilmore H Lee
08-31-2002 09:07:32
I once saw a man lift the front end of a model A international off the ground and I am curious as to how much it weighed.
kjm
09-01-2002 22:03:07
 Re: weight of front end of wide front model A international in reply to Gilmore H Lee, 08-31-2002 09:07:32
I have a friend who picked up the front end of a wd-45 one time, he did it but gave himself a herina doing it !!!!
LanceM
09-01-2002 14:29:30
I just gave mine a lift and he must have been one strong SOB as I wasn't able to get the bulge out of the tires and I'm no weakling...
Hugh MacKay
08-31-2002 18:38:33
I am thinking front end of Farmall SA is 1000 to 1200 lbs. My Farmall SA no weights added weighs 2350 lbs. My dad had a guy working as a farmhand , could lift front end of Cub but not the SA. There are likely guys that can do that. At 60 I am not going to try.
BIG JOHN
08-31-2002 14:54:29
Don't believe that there is a breakdown on axel weight but the entire Farmall "A" weights 1870 lbs. dry, without weights or fluid in the tires.
BIG JOHN
08-31-2002 17:49:25
 Re: Re: weight of front end of wide front model A international in reply to BIG JOHN, 08-31-2002 14:54:29
Sorry about this I gave you the weight (1870lbs) for a FARMALL "A". The weight of an INTERNATIONAL "A" is 2750 lbs. dry.
