Replacing PTO seal on 140
Gerald
08-28-2002 19:34:18
I have recently purchased a model 140. It is in good shape except the seal around the PTO shaft leaks. The question is....does the old seal come out by prying it with a screw driver or is there a special tool required. I have the new seal and it looks like just a pressure fit. Appreciate help and any tricks to replacing the seal. Thanks....Gerald
Haas
08-29-2002 05:55:30
 Re: Replacing PTO seal on 140 in reply to Gerald, 08-28-2002 19:34:18
The seal is a press fit. You may be able to get the old one out by drilling holes in it and screwing in some self tapping or sheet metal screws and using those to pry it out. Failing that, you will have to remove the complete housing in order to pull the shaft out so that you can drive out the seal from the back side.
Gerald
08-29-2002 06:03:12
 Re: Re: Replacing PTO seal on 140 in reply to Haas, 08-29-2002 05:55:30
Thanks Haas for the info..... Gerald
