Re: carb woes
Kendall
08-20-2002 07:07:19
A good tip I learned from someone on this site is to remove the plug that drains the carb, screw in a barbed hose connector and slip on a piece of clear tubing, turn it up and you will be able to see where the fuel level is in the bowl, kinda like those coffee pots with the glass tube on the side.
