How to get out sleeves
Jeanne
08-19-2002 13:15:47
We want to replace the pistons and sleeves on our 1942 Farmall H. How do you get the sleeves out?
scott AR
08-19-2002 17:19:24
 Re: How to get out sleeves in reply to Jeanne , 08-19-2002 13:15:47
The welder idea works good. Just make sure it has sleeves. I welded one that didn't have sleeves. When the machine shop got thru with it, it did.
Ryan Free
08-19-2002 14:04:35
They make Sleeve pullers, may try finding one at a local NAPA store. If your replacing the sleeves and just junking them, may try using a 2x4 and a hammer or hydrulic floor jack to force them out the top of the block.
F14
08-19-2002 14:34:49
 Re: Re: How to get out sleeves in reply to Ryan Free, 08-19-2002 14:04:35
If you have a welder, running a bead the length of the sleeve in two or three equally spaced spots will shrink it enough that you can tap it right out. Did that with an F12 block that a sleeve puller wouldn't even budge.
Ron in Az
08-19-2002 20:20:19
 Re: Re: Re: How to get out sleeves in reply to F14, 08-19-2002 14:34:49
My father-in-law and I made one with all thread and it worked great if you want me to take a picture of it, email me if I need to measure it. good luck Ron
Jeanne
08-20-2002 04:33:24
 Re: Re: Re: Re: How to get out sleeves in reply to Ron in Az, 08-19-2002 20:20:19
Ron, would like to see a picture of your homemade puller. send to dunworkin@nwonline.net
