IHC 140 Oil Filter Element
Gerald
08-18-2002 19:26:27
What is the correct oil filter element to use on an IHC 140? My tractor takes the inside element and not the screw on external filter. Looking for a manufacturer and part number. Thanks.....Gerald
Glenn(WV)
08-19-2002 05:36:25
 Re: IHC 140 Oil Filter Element in reply to Gerald, 08-18-2002 19:26:27
My uncle has used Hastings filters he purchased at an auto parts store, but like the others said, a Case IH dealer is the easiest way to go.
Haas
08-19-2002 03:51:59
A farm supply store such as Tractor Supply will have or can get the oil filter for your 140. If not in stock, they will have a Fram or similar application catalog there to pick out the correct filter and they will order it for you. I've used the Fram filters a time or two, but it's easier to go to an IH dealer because they will have them in stock at their parts counter.
Hugh MacKay
08-18-2002 19:56:21
Go to CaseIH, as far as I know they are only source.
