Best degreaser
getting ready to repaint.
Gibby
08-17-2002 06:13:41
I'm looking for suggestions on the best degreaser - I'm getting ready repaint my 300 after having been to liberal with the grease gun while I was using her.
Thanks
Dave
Diesel Don
08-18-2002 21:21:38
 Re: Best degreaser - getting ready to repaint. in reply to Gibby, 08-17-2002 06:13:41
I've had good luck with Davies DC99 and Simple Green.Use a rich mixture for heavy grease.If mixed real rich it will take off old paint also.
Michael Soldan
08-17-2002 14:39:56
Go with Cliff...oven cleaner works well and then take the pressure washer to it, oven cleaner makes a carburetor look like new, gets the baked on grease. I have sprayed varsol on grease and then after it has soaked in the pressure washer gets most of it , but oven cleaner works the most consistently and its cheap and readily available...good luck from Mike in Exeter Ontario
Ron
08-17-2002 07:12:24
You have to be careful but lye mixed with water works very good ( also removes paint at the same time) Look in the archives. Lye can be purchased a your local grocery ( it is drain cleaner) Make sure you wear rubber gloves and safety glasses. Nothingis better.
rhouston
08-19-2002 08:33:28
 Re: Re: Best degreaser - getting ready to repaint. in reply to Ron, 08-17-2002 07:12:24
oven cleaner is also lye if i remember right
Cliff Neubauer
08-17-2002 13:29:15
I've used diesel fuel to soften up hard grease, put some in a hand sprayer and spray the tractor down several times over a couple day period then power wash it. Use some cheap oven cleaner to finish it off.
